Nov 12, 2019
07:44 PM
Nov 12, 2019
07:44 PM
When I use the DFU function to update the firmware (PDL: 3.1.0), the cm4 kernel program cannot open the Bluetooth function and stops in the Cy_BLE_Enable function. I suspect that there is a stack overflow error, because I print the tracking information through uart, the program crashes for no reason. The following is my entire project, I hope you can help me.Thank you. !
12:10 AM
Nov 26, 2019
12:10 AM
Does you original app1/loadable project work finely without DFU library involved?
If it does, can you attach the original app1 here? I can mofidy it to fit for app0/loader application.
