NiBu_4687336
5 solutions authored 50 replies posted 25 replies posted
Hi.
Are there any examples of how to use the PDL's asymmetric cryptography facility? There is basically no documentation, and there do not appear to be any examples on GitHub.
I was able to implement AES encryption/decryption, working from the single example available, but without documentation or examples, there's really no way to approach the asymmetric algorithms.
-Nick
NiBu_4687336
Hi @Hari.
Thanks for the reply. The PDL link you provided is what I was referring to when I said there was basically no documentation. It contains no more information than you might find by examining the associated header file.
The RSA example is a good workaround for the weak documentation - it should be enough to let me move forward.
Thanks again,
-Nick
Hari
Hi @NiBu_4687336 ,
You can take a look at the PDL documentation for asymmetric key encryption on PSoC 6 - https://infineon.github.io/psoc6pdl/pdl_api_reference_manual/html/group__group__crypto__lld__asymmet...
We also have a community code example to showcase the RSA encryption scheme with a sample application - https://github.com/Infineon/Community-Code-Examples/tree/master/crypto
Please take a look and let us know if you require any further details.
Hari
NiBu_4687336
Hi @Hari.
Thanks again,
-Nick
