MuKh_4408861
Hi All,
Probably many people struggle finding good quality PCB manufacturer for small pitch Cypress BGA chips.
If you have any recommended PCB maker would be great to know.
I have PCB with CY8C6347FMI chip that consist via-in-pad and micro vias for that chip.
Here is most critical parameters
Min track/spacing 3.3 mil
Min annual ring size 0.05 mm
Min BGA pad size 0.27mm
BGA pad clearance 3.2 mil
Min Hole Diameter 0.15 mm
Thanks in advance.
Hari
Hi @MuKh_4408861
You can check out HiQ Electronics.
Hari
Hari
Hi @MuKh_4408861
Hari
