Dave_Long
10 replies posted 10 questions asked 10 sign-ins
Hi:
     There is a error "The SDK must be defined via the CYSDK environment variable. Stop. modus.mk" happened when I bulid the code example project on  modustolboxV2.2.How should I do to remove the error?
Rakshith
250 likes received 1000 replies posted 750 replies posted
Hi @Dave_Long
Can you please let me know if you downloaded the ModusToolbox projects from this link? - https://www.cypress.com/documentation/code-examples/ce216795-psoc-6-mcu-dual-core-basics
If that is the case, these projects are for ModusToolbox 1.0 as shown and are unfortunately not supported in ModusToolbox 2.x.
You can click on the New Application option in Quick Panel as highlighted in the snapshot below to import a code example for your target device in ModusToolbox 2.x.
You can also refer to this training session for an Introduction to ModusToolbox 2.x - https://community.cypress.com/t5/ModusToolbox-Blog/Session-1-Introduction-to-ModusToolbox-2-x/ba-p/2...
This GitHub page provides information about all the Code Examples for ModusToolbox 2.x - https://github.com/cypresssemiconductorco/Code-Examples-for-ModusToolbox-Software  and you can visit this link for all ModusToolbox 2.x Dual CPU examples.
Hope this helps.
Thanks and Regards,
Rakshith M B
Rakshith
Hi @Dave_Long
Hope this helps.
Thanks and Regards,
Rakshith M B
