I am developing a low-power application using CY8CKIT-062-BLE board.
I followed the application note "PSoC 6 MCU Device Firmware Update Software Development Kit Guide" (https://www.infineon.com/dgdl/Infineon-AN213924_PSoC_6_MCU_Device_Firmware_Update_Software_Developme... ) and configured a "map A" BLE DFU Memory Maps.
In the Application #1, I write the following function as the immediate alert service's event handler:
After Application #1 was successfully updated (the BLE name changed when I discovered it in Cysmart), I write a number 2 into the ISA service using Cysmart. Then, the BLE is disconnected, however, when I search device again, the BLE name of Application #1 was discovered. So, seems the system could not keep in the hibernate mode (no wake-up signal was applied).
Another phenomenon I observed is: In Application #1, I only call Cy_SysPm_DeepSleep(CY_SYSPM_WAIT_FOR_INTERRUPT)" in the for(;;) loop both in CM0 and CM4, the power consumption is about 400 uA, which is not as low as the manual(about tens μA). By simple calculation, if CM0 works at 4 MHz, CM4 works at 8 MHz, then the power consumption is about 400 uA. Seems the CM0 and CM4 are halted, but they are not working at 32KHz.
My questions are:
- Does the Application #0 (DFU application)'s configuration affect the execution of Application #1's low-power API?
- Are there any points that I should pay attention to when I implement the low-power application with the DFU Memory Maps.
Thank you very much for your patience to read my question!!
Any suggestions and hints are highly appreciated!
Sincerely!!
PSoC 6 MCU
I believe that this issue is already being discussed in this thread - <link>. We will continue our discussion in the original thread and I will go ahead and lock this thread.
P Yugandhar.
P Yugandhar.
