Hello, I currently benchmark a linear support vector machine on the PSOC63. I trained the model offline and stored the model coefficients directly in the C code. Now I examined the follwing behaviour:
When executing the prediction on the PSOC I can record different execution times for different model data (but still same dimensions). The differences are about 2% of the execution time.
How is this possible? Are there any numerical effects that are important?
Thanks in advance.
PSoC 6 MCU
I think it comes to how the compiler generates the assembly code to handle double precision point operations. The CPU only supports single floating-point operations, so it needs to combine multiple instructions to operate at double precision, which might take in consideration the number's signal.
Hi @Berni27,
Could you let us know the following:
- What is the model data that is being worked on? Could you specify finer details such as dimensions, etc?
- What kind of testing is being performed?
Could you share the project so that analyzing the same would be easier?
Nikhil
Hi @ncbs , thanks for the quick answer.
I use a linear binary SVM with 500 feautres. Data is stored using 2 double arrays with 500 values each (one for the coefficients of the SVM, one for the data/features to perform the prediction on). Furthermore, there is one double values that represents the bias.
I measure the execution time of the SVM prediction, which baisically is just this code snippet:
The behaviour I can measure is that as soon as I change the data and coefficients to other values, then the execution time changes. I do not understand why as always the same mathematical operations are involved.
Kind regards,
Bernhard
Can you try to disable the compiler optimization? Perhaps the compiler some how is able to optimize the code based on a given set of coefficients/bias.
If you are still seeing a difference, would you mind to share the project?
It seems the double operation execution time is affected when dealing with negative numbers. By simply changing the equation:
prob += coefficients[i] * *(features+i);
to
prob -= coefficients[i] * *(features+i);
You would get a different execution time.
@RodolfoGL thank you very much for your answer. Is there any explanation why operations with negative numbers are handeled differently?
