I used PSoC Creator4.4 to build a project named Chip Whisperer, and a compiler error occurred. The error is as follows collect2.exe: error: ld returned 1 exit status
The command 'arm-none-eabi-gcc.exe' failed with exit code '1'.
below is the project file
How to solve this problem? Thank you!
PSoC 6 MCU
Hi @niharika,
I believe the crypto library is not added to the project. Could you please open the project Build Settings > Customizer > Peripheral Driver Library and enable the crypto library as shown?
Rakshith M B
Hi @niharika,
Rakshith M B
Thank you 😄
