cynic_bandera
10 questions asked 50 solutions authored 25 likes received
Hi. I have zero knowledge of SW. I'm a hardware engineer. Could you step by step with pictures and code examples explain how to assign PWM signals to certain pins of the board when some events appear? I use MTB but have no idea how to do it...v Maybe let's do it together?
ADSW
250 sign-ins 50 solutions authored 25 likes received
Hello @cynic_bandera ,
Do you mean the CYSBSYSKIT-DEV-01 of the kit ?
You can start with example code : HAL PWM Square Wave by select the CYSBSYSKIT-DEV-01 as the BSP.
Thanks & regards
Andri
ADSW
Thanks & regards
Andri
