Hello, I was following Alan's Webinar and got as far as loading MyFirstProject and clicking the Program icon. The error message was 'Port Acquire Failed'. I tried the existing project from the web site 'MyFirstDesign' but still the same error. I did the usual of power reset and checking the cable. There was nothing else running. Any ideas? Cheers Bill
Hi
I was attempting to acquire a screen capture so I went through the same process as before and it started working (LED Blinking). I'm at a loss as to what I did different. Before I started this enquiry I did power it off a few times (even the laptop) and tried loading the program with no success. Anyway thanks for your help I hope I didn't waste too much of your time
Cheers Bill
Can you check the default jumper settings as explained in this discussion? - https://community.cypress.com/message/146080?et=watches.email.thread#146080
Checked and all good in default positions
Can you paste the screenshot of the error you are getting?
Try programming the hex file through PSoC Programmer (see if the device powered is getting detected or not) and see if it programs. If not, take a screenshot of the failed programmer screen and paste it here.
Hi
Cheers Bill
No probs Bill
Glad to know that it works.
