srini_a
50 sign-ins 10 questions asked 10 replies posted
Hello Community,
I have a project with both .c and .cpp files and would like to force the modustoolbox to use g++ compiler to compile the .c files. When I make the change in the <Project>->Properties->C/C++ Build->Settings->C compiler = g++ (originally gcc); this change is not taking affect. Any idea why this wouldn't work? Is there any step I'm missing?
Any suggestions would be helpful.
Thank you.
ADSW
250 sign-ins 50 solutions authored 25 likes received
Hello @srini_a
You can create a c++ project in ModusToolbox .
Can you try following the solution in this thread to do the same.
Warm regards,
ADSW
ADSW
Thread was locked due to inactivity for long time, you can continue the discussion on the topic by opening a new thread with reference to the locked one.
The continuous discussion in an inactive thread may mostly be unattended by community users.
Thanks and Regards,
ADSW
