PSoC™ 6 Forum Discussions
SungHyunKim
First solution authored First reply posted First question asked
Hi Modus Experts,
I got some build error with downloaded project file from github. please see what it is.
1. I downloaded mtb-example-psoc6-dual-cpu-empty-app  from Cypress github as zip file. then unzip it in my local space.
2. In MTB2.3, File>Import>Modustoolbox>Modustoolbox application import > select unzip folder > finish
3. then there are two project files show up in project explorer which are mtb-example-psoc6-dual-cpu-empty-app-master.cm0p_app and mtb-example-psoc6-dual-cpu-empty-app-master.cm4_app.
4. I tried to build each project but error message showed up that is ".../ModusToolbox/tools_2.3/make/startex.mk:380: *** Build support for the target device not found. Run "make getlibs" to ensure all required build and code dependencies are present.. Stop".
Could someone guide me what is problem on this? or how to fix it
thanks in advance -Sung Hyun
SungHyunKim
Please ignore this question.
I resolve it by opening the Library Manager in each project file and click Update. This runs the make getlibs operation to generate the necessary files and libraries.
I leave this question for other user who faces same issue.
Sung-Hyun,
SungHyunKim
Sung-Hyun,
