Hi @dhuyhx,
Seems like ModusToolbox is unable to access the repository. Can you please try cloning the PSoC 6 MCU: Hello world repository manually and let us know if that works?
Rakshith M B
Sorry,I don't know much about this practice about cloning the PSoC 6 MCU: Hello world repository manually .Can you give me any hint or website tutorial?Thank you.
Hi @dhuyhx
You can check this page to understand how you can clone the project from an Infineon github repository.
You will require an additional tool called git bash to do the clone operation if using windows. On linux this is not necessary and you can use git commands directly in the terminal after installing the git package.
Once you have cloned the project , you can import the same into ModusToolbox using one of the steps in the step Using the Code Example.
Warm Regards
Alen
l have cloned the project ,but still exist error.
Hi @dhuyhx ,
Can you please make sure that you have done the proxy settings correctly?
You can do this in 2 ways where one is by setting the environment variables and the other is by using the proxy-helper tool as mentioned below:
Using the proxy-helper tool, you can set the mode to "manual" and then specify your proxy.
You can run the proxy-helper tool by opening modus-shell and then navigating to the proxy-helper directory in the same and then running the commands mentioned in the proxy-helper manual attached here.
Let me know if this helps.
Warm Regards
Alen
This is previous proxy server settings.According to the instruction,l want to open the proxy-helper but it seems to have not respond.
Your connection to github.com is somehow intercepted and broken.
You can make MTB access the online content by VPN/tunnel to avoid the issue if it's available to you.
Or you can try to use the offline content package instead. See:
https://community.infineon.com/t5/Resource-Library/Use-Offline-Content-in-Eclipse-IDE-for-ModusToolb...
I try to click on the website to download the offline version, but I can't open it.
l have installed offline version successfully,but meet a new problem.Perhaps l install it in non-default location
