Dears
I would like to see complete build log of project in Modus Toolbox 2.4
During compilation process - in log window is updated text information. But after finished build / completion there is only a part of text in the window even if I scroll to up (or select all text in window). It looks like it was sometimes overwritten during the process .. It's available somewhere in the LOG file, I found some LOG in the TEMP folder, but the victim was only a few lines...
Is there saved complete build log ?
Radim
Hello @ravo
You can go to the following path in your system to see the build logs: ..Workspace\.metadata\.plugins\org.eclipse.cdt.ui\global-build.log
i.e. in your Modustoolbox project workspace, you will have a .medata folder. You can go to the above path in it to see the build logs.
Do let us know if you face any issues there.
Best Regards
Ekta
Hello @ravo
Best Regards
Ekta
Dear Ekta,
Thanks for answer. It is exactly what I need.
Best Regards
Radim
