When trying to program my application on Modus Toolbox, this error occurs:
Error: kitprog3: failed to acquire the device
Info : clock speed 2000 kHz
Error: Error connecting DP: cannot read IDR
Error: DAP 'psoc6.cpu' initialization failed (check connection, power, transport, DAP is enabled etc.)
Info : Power dropout detected, running power_dropout proc.
Power dropout, target voltage: 0.106 mV
** OpenOCD init failed **
shutdown command invoked
** Program operation failed **
srst_only separate srst_gates_jtag srst_open_drain connect_deassert_srst
Error executing event reset-deassert-post on target psoc6.cpu.cm0:
C:/Users/EKene/ModusToolbox/tools_2.4/openocd/bin/../scripts/target/mxs40/mxs40_common.cfg:115: Error:
in procedure 'ocd_process_reset'
in procedure 'ocd_process_reset_inner' called at file "embedded:startup.tcl", line 788
in procedure 'mxs40_reset_deassert_post' called at file "C:/Users/EKene/ModusToolbox/tools_2.4/openocd/bin/../scripts/target/mxs40/psoc6_common.cfg", line 134
at file "C:/Users/EKene/ModusToolbox/tools_2.4/openocd/bin/../scripts/target/mxs40/mxs40_common.cfg", line 115
Error executing event reset-deassert-post on target psoc6.cpu.cm4:
in procedure 'mxs40_reset_deassert_post' called at file "C:/Users/EKene/ModusToolbox/tools_2.4/openocd/bin/../scripts/target/mxs40/psoc6_common.cfg", line 169
Info : psoc6.dap: powering down debug domain...
Warn : Failed to power down Debug Domains
The exact application worked perfectly before but in the last few weeks this error keeps appearing and i dont know how to get it to work again. Everything seems to be as before so dont know why it is not working now when it was working previously.
Could it be a problem with the psoc 6 wifi bt prototyping kit itself? is so should i get a new one?
All help would be much appreciated!
Thank you,
Evan
Hi @EvanK4
Can you please share the hex file of your project here?
Since your logs show power dropout,
Is it possible for you to monitor the power supply and see if it is below the desired level or fluctuating?
Best Regards
Ekta
Which Evaluation kit are you working on??
I faced the same issue on CY8CKIT - 062S2 - 43012 Combo Kit
Basically the issue was with the J15 Jumper which was not connected properly. The voltage supply for the target was an issue. By placing this jumper properly, I was capable of resolving this issue.
