Dears,
I am unable to find "Tool Settings" under C/C++ Build as shown in some tutorials, manuals for Modus Toolbox IDE. Where are these settings in Modus Toolbox IDE - 2.4.0 version ? In previous release it was under Project Properties: C/C++ Build -> Settings as shown on this picture:
And for comparison - In 2.4.0 release the "Tool Settings" tab is missing:
Thanks in advance and Best Regards
Radim
Hi Radim,
Can you please let us know which setting are you looking for? In the recent versions of ModusToolbox, most of the settings related to the compiler are deferred to the makefile. So if there is any particular setting that you are looking for then please let us know. We will try to provide a workaround for the same.
In the image, I see that you have highlighted the usage of hardfp. For that, you can refer to this snapshot from the ModusToolbox User Guide -
Rakshith M B
Hi Radim,
Rakshith M B
Dear Rakshith,
thanks for response. I missed to see these notes in manual. I would like to see all settings related to FPU unit in PSOC6. If it is some settings still in IDE or all only in Makefile now.
e.g. these params:
DEFINES=ARM_MATH_CM4 ...
VFP_SELECT= hardfp or softfp // We are not able to use pure "soft" ?
CFLAGS =-mfloat-abi=...
I would like to test both soft & hard version - but compiled version in assembly is still same as described in another thread https://community.infineon.com/t5/PSoC-6/PSoC6-FPU-in-GCC-compiler-in-Modus-Toolbox-environment/td-p...
Radim
Hi Radim,
I believe the thread that you have shared is now resolved.
Rakshith M B
