PSoC™ 6 Forum Discussions
MSS
First reply posted First like given First question asked
Hi ,
 I have recently moved from Psoc4 to Psoc6, and the tool for the chip is Modus tool box.
We are using CY8C6245LQI-S3D42.
I started to create a sample project for USBUART and I see the following issue as in the below image. The tool is trying to do something from git and the git path does not exist.
As a starter it becomes difficult if we are unable to create examples.
Any help will be appreciable.
I am struggling with Modus tool box, I believe psoccreator was much better and easier.
MSS
ChristopherF_51
100 replies posted 25 likes received 50 sign-ins
This might be due to an issue with access to GitHub, but I am not completely sure. Does this article help?
https://community.infineon.com/t5/Knowledge-Base-Articles/Offloading-the-Manifest-Files-of-ModusTool...
ChristopherF_51
Ekta
250 solutions authored 100 likes received 250 sign-ins
Hi @MSS
I was able to build the code examples on my end. Could you please confirm if the workaround provided in the KBA shared in the previous response helped you to solve the issue at your end?
Best Regards
Ekta
