PSoC™ 6
JCD
New Contributor II
Hi everyone, excuse me.
I have an urgent question.
After Modus is compiled, the RAM usage size will be displayed. I found that the same code, on modus, the heap usage is very large, but it is very small on other compilers, so that my SRAM on MODus is about to exceed.
Total Internal SRAM (Available) 292864
Total Internal SRAM (Utilized with heap) 279920
thanks for your help
DheerajK_81
Hello @JCD ,
ModusToolbox allows you to configure your set of build tools using the Makefile. Please refer to the question "How do I specify a set of build tools?" in the following KBA for more information on how this can be done:
https://community.cypress.com/t5/Knowledge-Base-Articles/Managing-the-Makefile-for-ModusToolbox-v2-x...
Hope this helps 🙂
Dheeraj
DheerajK_81
Hello @JCD ,
Hope this helps 🙂
Dheeraj
Top labels
