- Email to a Friend
In my CY8CKIT-062S2-43012 board I looking for expanding RAM for operations of mallocs functions.
I have come across one example (QSPI_F-RAM_Access) where QSPI is used for reading and writing in F-RAM. I am not if this is the best example for expanding the RAM for the above purpose. Is that correct understanding?
I thought F-RAM has support for memory-mapped access of RAM but I can not find any example for that. Please share the link for such an example on any PSoC board.
PSoC 6 MCU
- Email to a Friend
Hi @jayesh_joshi ,
As of now unfortunately we do not have any such code example that looks for expanding RAM. However, I am checking with my team as well to find a way how we can help you here with the same. Thank you for your understanding.
Aashita
- Email to a Friend
Are there any steps using PSoC creator may be that I can use? A document also can be helpful.
- Email to a Friend
I have come across document which explains F-RAM in XIP mode and mentions examples as well on pages #3 and point#5. But when I open the link it takes me to all the examples but there is no example for F-RAM in XIP.
Has this been removed? Is there some issue with F-RAM in XIP mode?
- Email to a Friend
Hi @jayesh_joshi ,
The link which you have provided points to this code example : CE224034 – QSPI F-RAM Access Using
PSoC 6 MCU with SMIF in XIP Mode. This code example is present with PSoC Creator 4.2. Also, can you please let me know does your application use FreeRTOS or it is bare metal?
Aashita
- Email to a Friend
- Email to a Friend
Is it possible to convert this PSoC creator project to ModusToolBox? My application is working with modustoolbox.
- Email to a Friend
Hi @jayesh_joshi ,
Can you try using heap_5 option provided at this page here : https://freertos.org/a00111.html#heap_5 ? This is one of the heap memory management cases which you can try at your end. Also regarding your another query, at the moment the support for PSoC Creator is limited and we cannot guarantee importing of the CE in near future. However, you can refer that code example to get an idea of the flow of code while accessing F-RAM in XIP mode.
Aashita
- Email to a Friend
I have tried finding that example in PSoC creator as well but I can not find it. Can you please check at you end if that example exits? Example is #CE222967 in the document.
- Email to a Friend
Hi @jayesh_joshi ,
The code example which you provided link for is CE#224034. You can find it under code examples of PSoC Creator. I have shared an image for the same as below -
Pardon with the search. Sometimes CE Number would not pop-up even when you search for number.
Also, I have attached the code example project here for your easy reference. Please let us know in case of any further query.
Aashita
