Dear Support team,
I have add "retarget-io" lib to my project(offline BSP package ) successful base MTB2.4 , and have referenced cy_retarger_io.h in main.c, but it build fail. Could you have any advice? BTW i use "make getlib" command, the result as below .
You can try to fix the garbled output first, for better reading and diagnosis.
Anyway, your problem resides in the broken network connection to github.com.
It's recommended that you use a VPN/Tunnel to nest your network connection to github.com if it's available to you. It's the best solution to the issue.
Otherwise, please use the MTB offline content package to solve it. See:
https://community.infineon.com/t5/Resource-Library/Use-Offline-Content-in-Eclipse-IDE-for-ModusToolb...
Could you please share the platform and app which you are using? Also please share the setps to reproduce the issue. Let me try to reproduce and collect more data.
-Dheeraj.P.K
Hi @William_Zion,
We will try out the application that you have shared. From the information that you have shared so far, I see that the Library Manager is unable to detect the retarget io library. Can you please delete the mtb_shared and the libs folder and try running make getlibs again? Also, the command that you have used is 'make getlib'. Please use 'make getlibs' to import the libraries. The error message should have been something similar to this -
I am not sure why the error message is corrupted. Can you please let me know if you can consistently recreate this?
Rakshith M B
hi Rakshith,
Thanks for your support.According your advice,i have try to delete the mtb_shared and the libs folder and try running make getlibs,the result as below. BTW, due to network limited,i'm used offine BSP package to creat my project,I'm not sure it will cause the above problems. Could you have other advice?
