I have used below configuration to run an AWS example on PSoC board.
1. MTB 2.4
2. Board
CYSBSYSKIT-DEV-01
3. Example : OPTIGA_MQTT_Client.
I am trying to run this example without OPTIGA. After setting up a AWS configuration with auto generated certificates, I modified the configuration of the example. Here I have disabled the OPTIGA part in main.c and did the modification in mqtt_client_config.h by updating the certificates.
Code built successful and working till the Wi-Fi connection.
But after that the MQTT connection failed.
Error log :
MQTT connection failed with error code 0x8060009.
Help me to get this this resolved.
Note : I can ping to my endpoint through command line from system.
Hello Yong,
Along with change in the FreeRTOS config make sure to update the mbedtls_user-config file too. Consider using mbedtls_user_config.h file from WiFi_MQTT_Client example.
Hi Patilbhu,
Can you please share your code zip file with me? Also, please send the AWS configuration details.
Shreya
Please check once again whether the client certificate, client private key and root ca certificate are correctly given in the "mqtt_client_config.h" file. Also, check the broker address. The connection fails usually when those are not correct.
You can send the source code with the modifications that you have made. I will check if anything else is causing this issue.
If you want to use the auto generated certificates for OPTIGA_MQTT_Client project, you need to modify the configUSE_TICK_HOOK in FreeRTOSConfig.h to "0".
Hello Yong,
