sstadler
First question asked Welcome!
I am interested in designing a solution for measuring TDS (Total Dissolved Solids) in water and sending the data over the 12V power line to the receiving end where the data is displayed.
I remember using a PSoC for power line communication a long time ago before the PSoC PLC version was released.
If I want to combine using a PSoC for both TDS and PLC, which PSoC do you recommend?
Thank You,
Steve
Vasanth
Hi Steve,
Kindly refer the this appnote for PLC solution. The attached design files can be also used for your reference even though a solution in the exact voltage is not available.
I hope this is helpful for you.
Vasanth
VenkataD_41
Hi Steve,
We recommend you to go with PSoC5LP device for your application. Please go through the following application note on powerline communication with PSoC5LP device.
https://www.cypress.com/documentation/application-notes/an76458-psoc-5lp-high-voltage-120-240-vac-po...
Thanks and regards
Ganesh
Vasanth
Hi Steve,
Vasanth
