Cheok98
10 sign-ins First like given 5 sign-ins
I am facing a problem to build the matter door lock example using modus shell after changing the matter library from "shared git repo" to "local git repo".
The shell shows linking error when I tried to build the project as shown.
I think this problem is the same as the problem discussed in this post Solved: Re: Link error occurred in case "matter library" u... - Infineon Developer Community
But I can't find a clear solution in the discussion. Based on my investigation, I have found that the library is built to a wrong directory (ext folder) but by right it should be built to the "libs folder". (* Please correct me if I am wrong.)
And I believe that this is the reason that caused the above error.
Can anyone tell me what should I modify so that the matter library can be built in the correct directory?
Bhamy
100 replies posted 10 likes given 10 likes received
Hi @Cheok98 ,
This thread will be locked due to duplicate thread:
https://community.infineon.com/t5/PSoC-6/Linking-Error-occured-when-trying-to-build-the-matter-door-...
Bhamy Narasimha Shenoy
