I cannot find the component LCD_seg for psoc63 in Psoc creator.
Can you please help with this? I only have the graphic LCD components.
A.
PSoC 6 MCU
Hi @AlGi_4647181 ,
This is because the PSoC 63 device you have chosen for your project does not support the LCD direct drive, as mentioned in the Segment LCD Document
For example, If you check the data sheet of a PSoC 5LP(CY8C52LP) device you can see the following
Hence if you create the PSoC Creator project with this device ,CY8C52LP, as your target, then the segment LCD component will appear in PSoC Creator.
So please check the data sheet of your chosen PSoC device for LCD Direct Drive in order for the segment LCD component to be supported in PSoC Creator.
Hope this helps.
Hi @AlGi_4647181 ,
Hope this helps.
