GrCa_1363456
Level 6
Level 6
50 likes received Beta tester First comment on KBA
Step 4 of AN213924 "PSoC 6 MCU Device Firmware Update (DFU) software development kit guide", Section 4.3.1 "ModusToolbox instructions”, explains how to specify a linker script other than the default. In this step the tab called “Tool Settings” is not present in the ModusToolBox (2.4). Under that tab is folder for GNU ARM Cross C Linker which I think we need to specify the special linker script we will need. I can’t find these settings anywhere in ModusToolbox 2.4. Can you tell us how to specify a non-default Linker Script?
Alakananda_BG
50 likes received 250 sign-ins 250 replies posted
Hi @GrCa_1363456 ,
The easiest way to specify a on default linker script is to go to your makefile and add the path as shown in the below image
Alakananda
Alakananda_BG
Hi @GrCa_1363456 ,
Alakananda
