Is there an example of using TRNG on PSoC 6?
LeRu_2309541
I'm trying to use TRNG on the PSoC 6 and I find the API description in the PDL 3.0.1 not describing precisely usage for the first two arguments of the Cy_Crypto_Trng_Generate() function, namely GAROPol and FIROPol.
Is there an existing example of usage of this function?
Or how should I set up these arguments?
Leszek
VaisakhK_66
10 replies posted 5 replies posted First question asked
Hi Lezek,
You can refer to the below example for usage of TRNG in PSoC 6 MCU:
http://www.cypress.com/documentation/code-examples/ce221295-psoc-6-mcu-cryptography-true-random-numb...
Vaisakh
VaisakhK_66
Hi Lezek,
Vaisakh
Thank you very much.
