zhch_4550981
10 replies posted 10 questions asked 5 replies posted
Because routines are dual-core, our engineers in the dual-core to single-core work, compile a lot of errors, short time cannot be resolved;
解决了,找FAE帮忙改了一个单M0+工作的BLE工程
ShipingW_81
The answer is you can do that without any problem.
Can you let me know the specific issue when converting the BLE stack into single cm0+? Are you using PSoC Creator?
