I'm trying to create a BLE Broadcaster node that publishes the Time Service once a minute using only Advertiser packets only. Is there a code example?
Note: I do not want to support connections on this node. I realize that I can supply a UIDD with data as part of the Advertiser packet. I also have already created an Observer-only BLE node that can decode the advertisement data.
Len
Hi Len,
Have you gone through this Dynamic Broadcaster (Day 009) code example in the below link?
PSoC-4-BLE/100_Projects_in_100_Days at master · cypresssemiconductorco/PSoC-4-BLE · GitHub
Hope it helps ! If not please update the thread.
Ganesh
Hi Len,
Ganesh
Ganesh,
Thank you. I'll check it out. I'll have to convert it to PSoC6 but the principles should be there for the most part.
I did find information about changing the advertisement data such as code frags below that appear to work:
*((uint32_t *)&cy_ble_discoveryData[config_idx].advData[CY_BLE_ADV_PKT_0_INDEX_SERVICE_DATA_IMMEDIATE_ALERT+4]) = adv_count; // change the intended data.
Cy_BLE_GAPP_UpdateAdvScanData(&cy_ble_discoveryModeInfo[config_idx]); // Signal the new advData to the BLE stack.
Len.
Ganesh,
The PSoC4 API (CyBle_GapUpdateAdvData() ) is a little different than the PSoC6 BLE API (Cy_BLE_GAPP_UpdateAdvScanData() ) but basically the same.
Len
