PSoC™ 6 Forum Discussions
GoMa_1139756
Has anyone loaded a RTOS on to the PSoC 6 BLE Dev board?  If so, what did you load?  Thanks.
fabe_2238151
hello,
there is a very easy way to implement FreeRTOS in your project using the PSoC Creator 4.2. Open the Build Settings (right-click on the project --> Build Settings) and open the tab Peripheral Driver Library and look for RTOS. Then select the Memory Management and it's done.
Hope this helps
fabe_2238151
hello,
Hope this helps
HeLi_263931
Level 8
Level 8
A quick search for "PSoC6 freertos" yields the Cypress 101 series: http://www.cypress.com/video-library/PSoC-Software/psoc-6-101-lesson-1-4-freertos/579231
There is also the tutorial from IoTExport: PSoC 6 FreeRTOS - The First Example - IoT Expert
GoMa_1139756
Thank you for the great information
On Tue, Mar 27, 2018 at 1:26 PM, user_78878863 <
