Hello!
While working on a project with PSOC 6 (CY8C-0620WIFI-BT Kit), the IC CY8C6274BZI-D54 got too hot and project stopped working when given power through the USB cable of PC. Also, the software PSoC creator could not further detect this device CY8C6274BZI-D54 for uploading code again. Incase if the microcontroller CY8C6274BZI-D54 has got damaged, is it possible to replace the microcontroller CY8C6274BZI-D54 alone or will the board PSoC 6(CY8C-0620WIFI-BT Kit) will not work any further? Incase of replacement of CY8C6274BZI-D54 IC , how to contact Cypress?
Thanks in advance.
PSoC 6 MCU
Hi @swethad0204,
Can you please, let us know:-
1] For how long are you using this board?
2]Was this board working fine before?
3]From which source this kit was purchased?
In case this damage was due to your project, not only CY8C6274BZI-D54 IC would have been damaged but also other components on the board would have been damaged. So, replacing CY8C6274BZI-D54 IC would not solve this issue.
In case you have purchased this kit from cypress and you have received a damaged kit.
Please, let us know.
Warm Regards,
Gautami J
Hi @swethad0204,
Warm Regards,
Gautami J
