Is any demo kit based on PSOC 61 MCU ?!
Tim_Shih
250 sign-ins 50 replies posted 50 questions asked
Dear Receiver,
I would like to learn PSoC 61 MCU but I can't find any demo kits which is based on PSoC 61 MCU.
Most of kits are based on PSOC 62 or PSoC 63.
Is any demo kit based on PSoC 61 MCU ?!
Thank you so much.
ravo
10 likes received 5 comments on blog 5 solutions authored
Dear @Tim_Shih , as I know there is no kit with 61 device. This will be very usable. The KitProg3 is not compatible for programming, you must use full PSoC MiniProg4 programmer.
You can start with 62 and later change BSP to adapt your HW. I tried it and it work.
Radim
ravo
Radim
Tim_Shih
Hi Radim,
But I would like to start from PSOC Creator 4.4 to learn PSOC 61 MCU. Do you think it is ok ?!
Thank you so much.
ravo
Dear @Tim_Shih . Yes you can use PSoC Creator, I must use Modus because I am using PSoC 62 with large flash (and these devices is not supported in PSoC Creator)
Radim
