AfaqAzeem
First solution authored First reply posted First question asked
Hello!
Can someone guide me with IrDA RX pin configuration.
Actually my IrDA reception interrupt is not working. I am running my UART with DMA. It is running fine in standard mode. But when I put it in IrDA mode the reception interrupt is disabled.
Please share your suggestions. Any kind of help would be highly appreciated
Aashita_Raj
50 likes received 100 solutions authored 250 replies posted
Hi @AfaqAzeem ,
Can you please try enabling the "InvertRX" parameter as this parameter enables the inversion of the incoming RX line signal and it is only applicable when Com Mode is IrDA?
Also, since the discussion is already going on in your similar thread : https://community.cypress.com/t5/PSoC-6-MCU/SCB-IrDA-UART-reception-is-not-working/td-p/289534, please let us know if we can stick to that thread itself.  Also, please let us know in case of any further query.
Aashita
Aashita_Raj
Hi @AfaqAzeem ,
Aashita
