Hello community members,
I have been using ModusToolBox 2.4 for the last 6 months, but still trying to solve why indexing is not working in ModusToolBox IDE. I have been working with PSoC 6 development boards and writing firmware for the boards, but the different functions, enums, structures, etc. and not indexed within the IDE. I have to go through different source or header files to look at that functions and enums. This is very frustrating for me.
look at those red errors, they are not going anywhere, the code building correctly every time, but the indexing of every file is not working. Please help me to solve this issue. Do I have to change some settings in the Preference window or what, please help!!
Thanks & Regards,
Vivek Karna
- Indexing
- modustoolbox
Hi @vivekatamantya :
Please check the Indexer setting of Workspace in MTB IDE, Window->preferences->Indexer.
Below is the setting in my MTB 2.4 IDE.
Please also check the Indexer setting of Project in MTB IDE, Project->Properties->Indexer.
Colin
Did you close the "mtb_shared" directory?
If it's closed in MTB IDE, you can't use the index function, but it's linked when you build the project.
There're many files of project in the "mtb_shared" directory, and you can index the API after building the project.
Please check it.
Colin
Hello @Qi_Colin,
the above files are added with every project, do I need to add the "mtb_shared" folder also, which is present in the ModusToolBox directory? If yes, then how can I add this folder to the ModusToolBox workplace?
Thanks & Regards,
Vivek Karna
These files are in the "mtb_shared" folder in the red box like below.
Generally, this folder is auto generated when you create a new project or after using command "make getlibs".
If this folder is not in your IDE, please refer to section 3.7 of MTB user guide to regenerate it.
Colin
Hello @Qi_Colin,
Tried the steps, but the problem still persists. Please help.
Thanks & Regards,
Vivek Karna
Colin
