HI I want control the buzzer using the pwm i have used this example code https://community.cypress.com/message/243067#243067.
using this buzzer is coming and beeps continuously but for me i want on of for 1/2/3 etc time. how can we doing this ..?
Beep ON/OFF in CE can be controlled by Start / Kill(Stop) of PWM_2. In CE, it is controlled by PWM_1 on the circuit, and this can also be controlled by S/W. The following is an example of turning Beep ON/OFF with the duty ratio of PWM_1, so please refer to it.
Let's make the dice of seven eyes on PSoC 6 with CapSense & sound,version 2
If this is not your answer, please let me know.
Kenshow
Kenshow
