PSoC™ 6 Forum Discussions
jola_401441
Selected External Device Pin in the ADC component:
Selected External Vref Source with CTDAC
Selected Bandgap Value : External Pin (P9[7])
The DAC appears to work fine, output range 0-1.250V with 1x gain.
The SAR ADC doesn't read anything other than 0x7FF. It does work if I use the internal 1.2V reference instead.
The pin P9[7] appears to be free, even though it should be assigned to External VREF.
Vasanth
Hi Jon,
I hope you are aware of the fact that external reference of SAR is given through the VREF pin, which is dedicated for it. The reference to the DAC is given as a buffered input through one of the opamps . Please let me know if this did not solve the problem.
Vasanth
jola_401441
Also shows up as unused in the Analog routing:
Vasanth
Hi Jon,
Could you please share your schematic too. If you can share your project that will be best for us to test. In PSoC Creator ,  go to File -> Create Workspace Bundle -> Select minimal. Please attach the generated file.
Additionally did you connect the ADC external reference to the VREF pin in of the chip in your design?
Vasanth
Vasanth
Hi Jon,
Vasanth
