Hi all,
I am looking for a guide line about how to enable the DSP lib to use the dsp API in PSoC6 CM4 project.
Is there a document here? Or can someone help to provide setup steps?
Ray
Lingling,
Thanks! Because the link you sharing was an old topic in 2020, which is using MTB2.1, I am looking somethings newer.
And there is also somethings changed on https://github.com/ARM-software/CMSIS_5/
Actually, I find a way to use DSP lib now. Here is the step I try:
Step 1 (For the user does not install MDK IDE, if user already install MDK IDE, skip this step )
Clone the CMSIS git repository in a separate folder using the command
git clone https://github.com/ARM-software/CMSIS.git
I run it in the MTB2.4 terminal , and git clone to workspace folder, as below:
Step2 Modify makefile to add the path of DSP library, just like the post you sharing.
- DSP_DIR=../CMSIS/CMSIS/
- INCLUDES=$(DSP_DIR)/Include
- VFP_SELECT=hardfp
- LDLIBS=$(DSP_DIR)/Lib/GCC/libarm_cortexM4lf_math.a
(For the user installed MDK IDE, should use the path of MDK DSP lib)
Then, it should be OK to call the math function.
Ray
The following linker is talking about the DSP lib, you can refer to it:
Lingling,
- VFP_SELECT=hardfp
Ray
谢谢分享哦~
