Hi all,
How to use 2 CYPRESS Miniprog4 devices in One PC to Program 2 IC at the same time?
I didn't find any parameters in the burner that could tell the hardware apart
If so, how do I do it?Thanks!
Hi @Z31114027 ,
If you use Cypress programmer then it is very easy to choose a Miniprog4 between 2. But if you want to program using Modustoolbox 3.0 directly then this may be difficult. You need to program one after the other.
Can you provide some details on the use case you are trying to achieve? Also kindly provide the details of your hardware setup?
Bhamy Narasimha Shenoy
Hi @Z31114027 ,
