ArBh_290401
I am unable to make the switchover from  KitProg3(CMSIS DAP) to KitProg2  working. Is it possible to download the example program CE222221 to the CY8CKIT-062-WiFi-BT using KitProg3   ?
Rakshith
Hi ArBh_290401​,
Yes you can program the CE222221 hex file using PSoC Creator and KitProg3. I was able to program the Kit with the same hex file. Here is my log -
Programming device 'PSoC 62 CY8C6247BZI-D54 (CM4)' with file 'C:\Users\****\Downloads\CE222221_Voice_Recorder01\CE222221_Voice_Recorder02.cydsn\CortexM4\ARM_GCC_541\Debug\CE222221_Voice_Recorder02.hex'.
Device ID Check
Erasing of Main Flash...
Programming of Flash Starting...
Protecting...
Verify Checksum...
Finished Programming
Device 'PSoC 62 CY8C6247BZI-D54 (CM4)' was successfully programmed at 03/30/2020 23:28:52.
Can you please let me know the issue that you are facing?
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
Rakshith
Hi ArBh_290401​,
Device ID Check
Protecting...
Verify Checksum...
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
