Hi guys,
I am using CE220959:
CE220959 – PSoC 6 MCU Bluetooth Low Energy (BLE) Device Firmware Update (DFU) with External Memory
How to reset the PSP/MSP (process/master stack pointers) mode in this PSoC6 bootloader?
Please point me to the exact line of code
Ben
In cmsis_gcc.h, you find:
__STATIC_FORCEINLINE void __set_MSP(uint32_t topOfMainStack)
__ASM volatile ("MSR msp, %0" : : "r" (topOfMainStack) : );
and
__STATIC_FORCEINLINE void __set_PSP(uint32_t topOfProcStack)
__ASM volatile ("MSR psp, %0" : : "r" (topOfProcStack) : );
In cy_dfu.c, Cy_DFU_SwitchToApp, which is called by CY_DFU_OnResetApp0, switches to App1 by calling SwitchToApp. This function writes to the MSP register.
Could you please clarify, why do you want to reset PSP and MSP in CE220959?
Thanks and Regards,
Sudheesh
the bootloader of this testcase does not work.
We have been trying for weeks to make this bootloader work on external memory.
We have a violation like this one:
CM4 FAULT!!
SCB->CFSR = 0x00020000
r0 = 0x00000000
r1 = 0x08047784
r2 = 0x00000001
r3 = 0x00000113
r12 = 0x100c8248
lr = 0xfffffff1
pc = 0x08047800
psr = 0x40000040
The ARM CM4 documentation states that this usually a result of missing to reset PSP/MSP once APP0 gives control to APP1
Hope this clarifies
Ben
Hi Sudheesh,
any feedback on this?
Thanks and Regards,
Ben
and
Thank you very much for your feedback Rudolfo. I will check and comment.
