How to interface Dynamixel servos(AX12-A) with PSOC6 ?
PaKa_4331911
First like given
Greetings from India fellow developers !
          i have one Dynamixel servo(ax12-a) and a Psoc6 CY8CKIT-062-WIFI-BT looking for ways to interface the Dynamixel servo  with psoc 6 . it would be great if someone can guide me on how to do it with or without additional hardware.also it would be enough if someone can show me where to start.
thanks in advance!
Pallav Karya
WeGa_288606
Level 4
Level 4
25 sign-ins 10 sign-ins 5 sign-ins
Hi Pallav,
I am assuming that you are starting from ground zero. Let us start with the electrical/physical connections. Please see the attached block diagram for starters and please double check the details as I could have made mistakes this late my time. Especially because I do not have a servo so I cannot verify the specifications provided by the servo manufacturer website i.e. pin out and connector pins order etc... Trust but verify.
Please note: Do not power your kit from the LiPo 11.1V battery unless you know that you can. I have not checked if it provides regulated input anywhere. In this setup I am assuming your kit will be powered through its own supply source such as USB or other arrangements you have made.
Wess
WeGa_288606
Level 4
Level 4
Hi Pallav,
Wess
Thankyou for your invaluable time and effort we really appreciate that.
this got me started thanks again.
