PSoC™ 6 Forum Discussions
Dave_Long
10 replies posted 10 questions asked 10 sign-ins
Hi:
    In one project,I found tow same named fuction in the same .c file,how the modustollbox design which funtion to be build?
AlanH_86
100 replies posted 50 replies posted 25 solutions authored
If you look in the directory emwin/latest-v5.X/ you will find a file called ".cyignore"
The modus build system looks for that file... and then it it ignore all files/directories listed in that file.
You will see in that .cyignore it has
Config
Sample
Tool
Which is why those are ignored.
Alan
Rakshith
Moderator 1000 replies posted 750 replies posted 500 replies posted
Hi @Dave_Long
When two files of the same name exist in a ModusToolbox application, the auto-discovery selects the file that has the smaller path relative to the application directory.
In your case, the configuration file in the folder emWin_config will be selected.
Thanks and Regards,
Rakshith M B
AlanH_86
Config
Sample
Tool
Alan
