Dear Community,
I have purchased the PSoC® 6 Wi-Fi BT Prototyping Kit (CY8CPROTO-062-4343W) to test the Wi-Fi and Bluetooth.
But I can't find ant example code to test the module.
Is there any software available with Wi-Fi configuration?
I installed the ModusToolbox IDE, and not the Wiced software, because I read somewhere that this version of the prototyping kit is not supported by Wiced.
If I'm wrong please tell me.
Kind regards,
Sergio van Vliet
I checked with the team and we have a few AWS PSoC 6 + WiFi projects here: https://github.com/cypresssemiconductorco/AWS_IoT_Publish_Subscribe_Code_Examples
that will help you get started.
Note that you will need to port this code over to your mbed enabled PSoC 6.
There is more documentation on this process in Chapter 3 of the ModusToolbox User Guide (Mbed OS to ModusToolbox flow) located here: https://www.cypress.com/products/modustoolbox-software-environment
This kit is supported within the ModusToolbox Mbed SDK
Dear Michael,
I downloaded and installed the ModusToolbox Mbed SDK, but I couldn't find any example code for enabling or configure the WiFi.
Is there any code available?
