PSoC™ 6
AyKo_4382201
I'm using CYBLE-416045-02 mcu and want to change PWM Alignment during run time.
Please Help.
Len_CONSULTRON
Level 9
1000 replies posted 750 replies posted 500 likes received
Level 9
AyKo,
If you allocated the PWM at the HAL-level, then you can make a call to cyhal_pwm_init_adv() (Hardware Abstraction Layer (HAL) )  In this call, there is a parameter for alignment.
You will probably have to perform a cyhal_pwm_free() first to have the halmgr free up the resources on the previously allocated PWM resource.
If you allocated the PWM at the PDL-level, I believe you need to perform the following steps:
  1. Cy_TCPWM_PWM_Disable();
  2. Cy_TCPWM_PWM_DeInit();
  3. change the .pwmAlignment varaible in the cy_stc_tcpwm_pwm_config_t  to the alignment type you want.
  4. Cy_TCPWM_PWM_Init();
  5. Cy_TCPWM_PWM_Enable();
Len
Len
Len_CONSULTRON
Level 9
Level 9
AyKo,
Len
Len
