Dheerajrb_IITB
We are working on the building  of an Agristation for agriculture diagnostics so we want to know how many communication protocols  SCB's can be implimented in this  Development kit .Then also it states that this CY8CKIT-062-WIFI-BT has 56 programmable Digital blocks and 7 programmable Analog blocks  but where are the GPIO's that can be used for the TCPWM,Universal Digital Blocks and these SCB's and then ADC,OP amp's.Could you please help us about this so that we can make a blue print of How many sensors can be interfaced with this development kit.
Rakshith
250 likes received 1000 replies posted 750 replies posted
Hi @Dheerajrb_IITB
The CY8CKIT-062-WIFI-BT Kit uses the following PSoC 6 device - CY8C6247BZI-D54. You can start by referring to Table 8 of the datasheet Multiple Alternate Functions which provides details regarding the different functionalities of each GPIO. However, as you are using the development kit, some of the pins might not be exposed. You could refer to Table 1-1. Pioneer board pinout in the Kit User Guide for details regarding the functionalities of the GPIOs in the kit.
Thanks and Regards,
Rakshith M B
Rakshith
Hi @Dheerajrb_IITB
Thanks and Regards,
Rakshith M B
