PSoC™ 6 Forum Discussions
JoYa_4324706
10 replies posted 10 questions asked 5 replies posted
I'm trying to use 400kbps as desired data rate for my I2C component, but only to discover that the SCB clock (kHz) generated by PSoC Creator itself is set to 7500, which apparently to be out of range. Is there anyway to help understand how this clock value is generated while I'm not using external clock terminal?
Thanks!
Best,
Joseph
MotooTanaka
Level 9
Level 9
I think that the clock to the SCB block is not directly to the I2C clock but for the oversampling it is supposed to be 16x faster.
While ago, I posted the following test program,
MCU Tester, a Swiss Army Knife for PSoC (CY8CKIT-062-BLE version)
Although I2C speed is set to 100 (kbps) you can easily changed it to 400 (kbps) from the schematic > I2C tab
Then could you test if the program works with your 400kbps component(s)?
moto
MotooTanaka
Level 9
Level 9
moto
