Hello everybody.
I want to tune the ECO clock for PSOC6 board I'm developing.
In the section 4 "Crystal Tuning Technique for ECO" in the document "PSoC/PRoC BLE Crystal Oscillator Selection and Tuning Techniques", the description as below can be seen.
"For tuning, the ECO clock is routed out of the chip to a GPIO to measure the clock accuracy."
So, I'm going to output the ECO clock signal to GPIO for checking and tuning the ECO clock frequency. But I have no idea to output ECO clock to GPIO pin.
For PSoC4, it can be seen in section 4.1.2 (maybe in the code 1).
I want to know how can I assign the ECO output to GPIO for PSoC6. I couldn't find the method for PSoC6 in Modus Toolbox 2.2. Please let me know how to.
Thank you for reading.
PSoC 6 MCU
If you can't use the HFCLK[4], you might try to use HFCLK[1]. This drives the audio subsystem. You will not be able to drive the ECO directly to the output pin, but you could use the PDM/PCM block. This block generates a clock based on HFCLK[1]. It will divide the clock though. It drives the clock signal through P10[4] or P12[4].
Hello @KeTS_3297816
You can refer to the following KBA: https://community.infineon.com/t5/Knowledge-Base-Articles/Route-Internal-Clock-Out-to-a-Pin-in-PSoC-... that mentions how to route the internal clock out to a pin.
In your case, you need to use ECO as the source of the input clock (instead of WCO as mentioned in the KBA).
Best Regards
Ekta
Thank you for your reply.
My system uses P0[0] as WCO input and P0[5] as PMIC Wakeup Output.
I think these pins have no alternative pin, so neither P0[0] or P0[5] pin can't assign to the clock output CLK_HF4 External pin.
I didn't mention the above situation before, sorry.
Is there any other substitution?
Thank you.
Sorry,
MCU is CY8C6347FMI-BUD53.
I don't use P12[4], and I can adopt the method you proposed above. I'll try that.
Thank you.
