How can I modify only a specified section of Flash during development?
I would like to be able to program a 2nd firmware image in a location offset from an existing firmware image on a PSoC 61 such that I can test modifications to the 2nd firmware without affecting the first.
Greg
PSoC 6 MCU
Hi @GrCa_1363456 ,
We are releasing a code example for the same, it will be available publicly. I have shared a pre-final version code here, which allows you to switch between 2 applications with a press of a button.
Thanks and regards
Sobhit
Greg,
Theoretically what you're asking to do is what a bootloader does that has a dual (or triple) personality. Many of the KitProg versions support multiple personalities.
I'm not your best source for implementing this feature. Hopefully someone else can weight in.
Hi @GrCa_1363456 ,
Thanks and regards
Sobhit
