viking_xie
I'm usingCY8CKIT-62-WIFI_BT board and PDL v3.1.4.
When wakeup from deep sleep the code at line 2883 of file "cy_syspm.c" will trigger hardfault.
while(0U == _FLD2VAL(IPC_STRUCT_ACQUIRE_SUCCESS, REG_IPC_STRUCT_ACQUIRE(CY_IPC_STRUCT_PTR(CY_IPC_CHAN_DDFT))))
I attached to the running target, I found the wrong value in  struct "cy_device"
cy_device->ipcBase is not 0x40230000 but 0x00000000
cy_device->ipcStructSize is not 0x0020 but 0xFFFF
So the macro "CY_IPC_STRUCT_PTR(CY_IPC_CHAN_DDFT)" result an access to a wrong address.
I moved this macro to the location before __WFI(), see the picture below, it works.
But I have no idea whether thers is still something wrong.
I don't  why it read a wrong values from flash (cy_device pointed a area in flash).
I dumped the flash by programmer, I found the flash data is correct.
Who can tell me what's going on.
Rakshith
250 likes received 1000 replies posted 750 replies posted
Hi @viking_xie
Can you please check these discussions and let me know if it helps -
deep sleep being blocked by IPC
Updating PDL syspm Driver for Hard Fault Problem – KBA229335
Thanks and Regards,
Rakshith M B
Rakshith
Hi @viking_xie
Thanks and Regards,
Rakshith M B
Thanks for reply. The solution your mentianed is the same to mine. I have learned the reason from upper link. Thank you very much.
