zhch_4550981
It looks there is no existing code example fitting for your transmission flow chart.
The following code examples are made for PSoC 6 BLE throughput measurement - ce222046ce212742​. Not sure if they meet your reuirements.
Len_CONSULTRON
Level 9
Level 9
zhch,
What will you be using on the Android for the BLE?
Is your goal to type text on the PC and see it on the Android app?
Len
Len
In order to test!
YES!
zhch_4550981
This project only has the ability to print from BLE to uart。
What about the two mentioned in post#3?
