PSoC™ 6 Forum Discussions
tam-s1201
5 sign-ins First question asked Welcome!
Hello, I am currently having trouble trying to complete one of the first tasks for the hello world exercise. Mainly because am using a Macbook and am unfamiliar with how the terminal works here.  After opening up the Terminal on MacOS, I am trying to select the KitProg3 COM port and then set the serial port parameters to 8N1 and 115200 baud.
ninadwaingankar
Moderator 25 sign-ins 10 replies posted 5 solutions authored
Hi @tam-s1201 ,
You can use Serial Tools which is available on the apple app store. Using the Serial tools you can select the KitProg3 COM port and then set the serial port parameters according to your UART configuration. Please follow the instructions provided in the following KBA for configuration.
Testing a USB-Serial Bridge Controller Configured as USB-UART with Mac® OS – KBA92549
Thank you!
Ninad
ninadwaingankar
Hi @tam-s1201 ,
Thank you!
Ninad
