Mrinal
Level 4
Level 4
First solution authored 50 replies posted 25 replies posted
Hello
I have used PSOC 4 and 5 since long and I remember that Ports 0,1,2 and 3 are connected to HSIOM in PSOC 4. Therefore UDB output can be routed through only these ports.
I am using PSOC 61xx MCU and there are 13 ports, I would like to know which ports support UDB connections out of the 13 ports and where can I find more information on this.
Also, there are two smart IO ports that support Boolean operations. Does this consume the UDB resource?
Thank you
Krupashankar
500 replies posted 50 likes received 25 likes received
Hi @Mrinal ,
PSoC 6 supports 12 UDB. The below picture contains array of UDB in PSoC 6
Refer to TRM PSoC6: https://www.cypress.com/file/399201/download
Except port 3 and port 14 all the port of PSoC 6 supports UDB
Port which has DSI will support UDB please refer to datasheet
Datasheet : https://www.cypress.com/file/385931/download
Krupashankar
Krupashankar
Hi @Mrinal ,
Krupashankar
